Hi all,
Im a new owner - I have just bought a 2002 RS172 with only 16k on the clock and FRSH. So far Ive added:
1. Green replacement filter
2. Rear luggage net!! Required for those roundabout smiles!!
3. Front and rear OMP strut - to be fitted, no one mentioned I had to put holes in the bodywork for the front one!! Not sure now?!?!? Rear is simple bolt on!
4. Front 182 splitter going on this weekend
So; here are my questions if you are able to advise me?
1. Is it worth fitting the front strut - if so how easy is it?
2. Do all RS172s feel a bit lumpy on tick over? - I had a Volvo C70 T5 GT before and prior to this an Audi TT 180BHP company car.
3. I want to remove the dash, I found all the screws; 3 in window vents, 3 behind left side chrome trim and 1 behind right side, 2 behind steering wheel cover and lastly the plastic ones each end - I removed the piller covers but it still seemed to be stuck around the passanger airbag area??? Didnt want to force it so put it all back together. I need to access the clocks to change the clock colours to white/blue as on the forum, I also want to locate a rattle coming from the front de-mist vents!! Ive seen you can select this help on the Cliosport site but Im not a memeber at this time - is it possible for someone to e-mail me the instructions? Mny thanks in advance. For the record the/my RS172 would out gun my TT without any problems almost all the way except top speed, but then when can you do that kind of speed anyway?! The Volvo was far quicker once into 3rd gear but this is down to pure torque from the 2.3 high pressure turbo unit - but the first corner, the RS172 would sail by.....Its a fantastic, fun, sporty, small, mad, cheap to run, great looking, scary pocket rocket and I love it so far.
Thanks in advance.
