gearbox and driveshafts can be used on both, they are slightly different in terms of design, but you can safely use the 1.4 ones with the 1.8 and vice versa. In terms of engine mounts I'm not 100% sure, I know you will be able to use the 1.4 dogbone and gearbox mounts but I'm not too sure about the top mount, or how well the dogbone and gearbox mounts will stand up to the 1.8.
The gearbox and driveshafts can be used on both, they are slightly different in terms of design, but you can safely use the 1.4 ones with the 1.8 and vice versa. In terms of engine mounts I'm not 100% sure, I know you will be able to use the 1.4 dogbone and gearbox mounts but I'm not too sure about the top mount, or how well the dogbone and gearbox mounts will stand up to the 1.8.
This is actually for a volvo 480 turbo conversion. I figured rather than buying a whole RSi. If the 1.4 gearbox bolts onto the RSi then it must bolt onto the volvo engine as its basically the same (i'm told). I can buy the other engine mount if required and the wiring loom off the RSi i'm looking at.
The car isn't being built for speed so having 1.4 driveshafts ahouldn't be a problem i'm hoping..and it will save me a bit of cash too...if it all fits together of course.
