RSTuner used as code reader on any car?
  182, SQ7, Trafic
Once the RSTuner is used on a car it locks to it.
Is it possible after this to read/clear faults on other clios without unlocking it?
  Bumder With A Buffer
So I could use my RStuner to read his fault codes and clear them if necessary?
Danny you could be in luck if so :)
  Black R27, 205gti
Did you get an answer? I'm having same problem. Progged by 182, but unable to connect to a 1.2 to read faults. Says unrecognised VIN. So looks like it's locked, even to just read the ECU.
