RSTuner User's 182.
  Iceberg 172 Cup
What specific files will i need for my 54plate Clio 182 (2004)???
Yes, i've searched but i need confirmation as i've just ordered RSTuner. :)
A helpful reply will be greatly appreciated.
Thanks!
:approve:
  SchwepTek™
You will have to wait and see what version ECU you have when you plug it in to your car.
It will more than likely be the CB22 files that you need.
  Iceberg 172 Cup
thanks mate, i've just read through the *.pdf file supplied by fastchip, seems theres alot to remember but really it's quite easy....
do most people do a complete ECU reprogramme?? or just a partial *.cal file or whatever? or does it depend on the car?
  Golf GT TDI, IS220d
iirc you need to run the rst. file 1st then the cal. file
I think if your first 4 numbers (i.e 8200_7C03.rst) already match a cal. file, you dont need to run the rst. file but in most cases a rst. file is needed
You would then follow that rst, file with 8200_7C03 RON98 CB6K aug 2008 .cal
^ Just an example, hope that helps just make sure you read though the manual a few times beforehand
