Rumbling sound from front
  Mk2Ph2 Clio 1.2 16v
The last couple of days I have noticed a loud, rumbling sort of noise coming from the front of the cabin/engine. At first I thought it might have been a hole somewhere along the exhaust causing the noise, but as it only happens when driving over 20 it didn't quite match up, so I'm absolutely clueless.
Any ideas???
  Mk2Ph2 Clio 1.2 16v
Tried swerving and the sound more or less goes completely when steering to the left and says the same whilst turning right as it does in a straight line.
In guessing its a new wheel bearing job then
  182cup & 172 racecar
A rumbling sound from front?.Plus if you jack the car up then grab the wheel top and bottom,there should be no movement when you pull and push,if there is then bearing has play in it.
