Scorpion Decat?
I've fitted one to an otherwise standard system, all joints are the same as the cat so it should slot straight in, but the one I fitted seemed about 2cm too long, I had to shift the rest of the exhaust back for it to fit and this resulted in the tail pipes sticking out a bit. Not a bad priced system though.
Cheers :)
Will hopefully be having a New Custom Centre Section made up when Funds allow so that would sort the Sticking out tips as I have Magnex Backboxes on it at the minute and miss the Rasp of when I had it Decatted before :)
