Scraping when turning steering
  1.2 mk2 renault clio
Hi i have just ran into a problem with my clio where when i turn my steering at low speeds there is a scraping metal on metal noise but isnt constant thought turning only at sertain times, currently under car having a look and a wobble of steering components
If someone can help that would be great.
Advikaz
I’d get that up in the air and get someone to rotate the wheel each way whilst you look for the source on the underside mate.
Martin_172
that to me sounds like the suspension top bearing is seized and that noise is the rubber on the body, when it makes the noise does the steering want to turn back the opposite way as you let go?
D
No just the noise ill have a look at the top bearing when home what are they like to replace if it is that
Martin_172
Fairly easy, jack up, wheel off, shock off, spring compressors on, undo top not, replace bearings (id get a kit with the rubber doughnut etc too) and refit all, 10-15 mins a side
Jacked up and turned steering with no noise but dreadful noise when driving slowly and turning is your bets still on suspension top bearing
With the weight off the suspension it is likely to be top mount related.
Thought that put it back on the floor and tryed and still no noise but solved problem with helper driving car and me having a look it is left and right track rod ends and the right ball joint are away
