screen washer pump
how do i know when its the pump that needs replacing of if its just the jets that are clogged? I can only get a tiny amount of water coming out of the front nozzles, and nothing outo of the back, like the pump has no pressure to it
also, where abouts is the pump located if i do need a new one?
pump located under wheel arch liner iirc sits on side of water reservoir, disconnect rubber pipe that leads to jets and see if it pumps water out from there and secondly but most im portantly you have to put water in it ........... make sure 1st!
what car? to get to the pump you need to take off the black plastic & wipers, new pump is about £25 i think
Pumps are only cheap halfords sell them under £5 i think.
Its most likly the pipes blocked get a pin or blow air down them etc to get rid of the blockage.
