self learning ecu
Car  AMV8, Mk1 Golf
do clios have a self learning ecu?
i have a manifold air pressure sensor fault and the new part comes 2 nite, but i cant get the fault code removed from the ecu untill tuesday.
will the ecu recognise there is a new part and run fine or will it continue to think there is a fault with the part and still run like a bag of shite
if the fault no longer exists it will eventually delete the fault code,so long as you change the part causing the problem your fine
