Serv/Abs light
Car  Astra VXR 17/05/07
Twice in the last week my Serv and Abs lights have stayed on after starting.If i turn off and start up again they go out :confused:
182 - 5500 miles
Anyone else had this or any ideas why ??
Cheers :)
the abs upon starting does a self test if alls ok then the light goes out. it must be finding a fault when first testing. maybe a high resistance in a wheel sensor causing a circuit fault. let a dealer check it with clip.
There is a Technical note out about ABS/SERV coming on on 182s adjustment of the brake pedal/ new switch if the light still comes on after the adjustment.
182 - 5500 miles
Cheers :)
where are you...i have clip and can do the test for you.
i am in devon.
there is but normally the light will go out and then will come on after driving and applying the brake
182 - 5500 miles
Cheers :)
i am in devon.
where did you get a khan box from? renault only sell them with clips at 2k. or have you used something else. ive got a clip set up but have to keep bringing home works kahn box.
Thanks for the replies,sorry for not answering sooner but i1ve been in work all day :sick:
Clarkiev6 many thanks for the offer,im miles away from Devon but appreciate your offer.:)
I mentioned to my dealer last week about it staying on then not staying on after restarting and they told me they did a test and nothing showed up or was stored in the memory whatever that meant :confused:
So this is a known fault if i understood the replies properly ?
What do i need to tell my dealer bearing in mind they have allready ran a test ?
Obviously i tell them its happened again but its always better going back with knowledge and a request for them to act upon it.
