weird that because we still get the fault on both sides. is that stated on the tech note then?Quote: Originally posted by 172 Exclusive on 01 June 2005
The RUK Fix is to cut the connector out and solder the wires..
Why? because the connectors are Sh*te..
On the MK 1 (1998-2001) you remove both Drivers & Passenger Connector.. On the MK2 (2002 - on) you only Remove the Passenger side Connector..
