SERV light after changing uch.
Car  1.2 clio dynamique
As the title states my 'SERV' light is on after i changed the uch/ecu, i presume this is due to me not realizing the new key needed to be synced before trying to start it. Do i have to take the car to a Renault stealer to get this turned off or is there an easier way to do it?
Sorry if this has been asked before, did a search but couldn't find anything similar.
If you've got the UCH/ECU/KEY all from the same vehicle then it should be plug and play afaik.
Not entirely true... Different vehicles have different specs. Some have xenons, some have rain/light sensors and the UCH's are configured to each individual car. If you put a UCH to a car that it's expecting say a rain sensor on and it doesn't have one then boom, there's a configuration miss-match and so light goes on.
You will need the services of someone with CLIP to re-configure this for you to get rid of the w arming lights.
Mick
Yeah the UCH is expecting rain sensor and auto lights i think, Glad to know it can be re programmed to sort though, i shall hunt for someone with CLIP.
Cheers for your help and sorry for the massive delay in reply!
