serv light and traction light
Car  clio 182 ...........
keeps coming on and going off been looking at past threads no one seems to no a fix any ideas thanks marc.............
also 1 setting on cruise control dont work. a lad at work says mite be a sensor broke on the wheel ............
Exactly the same as me... Diagnostics showed brake pedal switch, adjusted as per guide on here and solved the serv and TC light however my cruise wont set which I believe means I need a new switch
I to have this problem and diagnostics shows as break pedal switch could you please link me to the guide which you followed to sort it. Thanks in advance.
messed around with brake switch cleared serv and traction faults then engine managment light came on any ideas ....
