Service and airbag light fix
Car  172 Cup
If you have fitted an aftermarket steering wheel and cannot get the SERV and airbag lights to go out, check the passenger side grab handle airbag switch connector.
I have a sabelt wheel, fitted 3.3ohm resistors, lights still present, i then checked all the connections under the seats and they were fine.
I knew a had an open circuit somewhere, so removed the grab handle to find that the airbag on/off switch connector underneath was loose.
Connector pushed in and lights are now gone.
It has taken me a while to get to this stage so i hope it helps someone out. I was certain i was going to need a CLIP diagnosis, not to mention that the lights draw attention at service time.
