service items
Car  FF 182 Sport
hi - just got me a 182 and im not sure when it was last serviced, its done 15k since 2009 when it had a full service/cambelt change but no further data
so to be safe im taking it in for oil/oil filter change and then doing the rest myself, which bits do i need?
Air filter - which make and price?
pollen filter - necersary or too much work to be worth it?
plugs - which ones are best and price?
is that it? or is there more too it?
i always service my own cars so i dont get robbed by some stealer, brakes tyres and fluids are sound, but could change if reccomnded?
oh its done 80k belts and service all done at 66k.
cheers lads/lasses
After 15k miles it's due new oil and filters, at least doing it all yourself you know it's DONE. Might as well change the sparkers as well.
5w 40 5 litres of car lube
bosch oil filter
75w80 GL5 gearoil (optional but i would)
NGK PFR6E10 spark plugs
air filter (k and n panel filter if you dont want to keep replacing them)
and pollen filter (deffo do this, takes 5 mins and mine hadnt been changed since it rolled out the factory)
done
don't forget sump plug washer, i couldn't get one did an oil change at the weekend guess what.................... sump plug is leaking :(
at least the engine will get a nice little flush with some quality oil :o
bosch oil filter
done
Gear oil....?????? How do I change that????
Drain plug is under the gearbox, 8mm. plug required to undo, same as engine oil sump. Filler is a black or white butterfly nut at front of gearbox abou 1/2 way up and it faces the rad.
