Just had the car serviced at 35k at a local independant garage which use only gen renault parts (to keep Renault Warranty), cutting a long story short my SERV light is now on and my air bag light is on in the top right hand side any ideas?
Probably the connection under the seat mate. common fault. If you have a Mk2 172 or 182 i would check the wiring under the passenger seat, have a fiddle with it make sure nothings popped out etc and see if that helps.
If not there is a guide on here to cut and re-join the wires to sort the problem
