Servicing best prices...
Cups just done 55k miles and needs to service, just spoken to renault and they want £313.17 for a service, these seems steep. What should i be paying?
What service is it? Where you located.
Basic 12k service should be £150ish.
Not sure what service it is, car had last service around 38k and had cambelt done. Now on 55k miles, so needs whatever is next one?
They have also quoted me £270 front and £190 for wheel bearings, this seems alot?
It's 5k overdue a 12k service by the sounds of it, seriously go to a specialist, they'll be cheaper than Renault and know what they're on about.
Where you located?
Do the wheel bearings need doing? Full set of rear disks, with bearing in is about £100 + fitting (easy)
No idea on front as never done them.
whats your location? If you want to go to renault I would buy the parts cheaper off here or on renaultsport cheaper & just get the dealer to do labour
S
Live near croydon and work in heathrow......not sure if its wheel bearings, i have a droning noise thats really bad.
I want to use a specialist but do not know any that are close by. I dnt trust renault but i need to use the car daily so im in a corner.....can anyone help. Need the work done tomorrow or day after...
Im from the North East and just booked my car in for a full service. £220 inc. spark plugs and £150 without. Also had a rear wheel bearing changed last year for £60 parts and labour. I use a Renault specialists called Mendall Motors i couldnt rate them high enough!!
