servicing question
rsc
Car  renaultsport clio 182 cup
just a question what does a 36000 service involve on a renaultsport 182 cup cheers stu
guess AUX Belt kit is the biggest thing.....
had mine done at 36,000m
should get gen renault belt kit fitted for around £240 ish at a good garage
then plus a 36,000m service
From Eddes guide:
Change oil (for a 5/40 oil this is important to check some dealers use 10/40 as per normal Clio’s)
Change oil filter
Change air filter
Change passenger compartment filter (if appropriate)
Check bodywork for rust etc (this is part of the Renault anticorrosion check)
Check brakes for wear, failing seals, fluid level (the reservoir on the 172/182 is at the back of the engine on the driver’s side on the bulkhead. You need to remove the engine cover if fitted to see if often as it is in an annoying place)
Check power steering fluid level/pipes
Check exhaust
Check condition of the rubber gaiters on the steering rack
Check the coolant level (big tank attached to the back of the engine bay on the passenger’s side of the car. Top up etc as appropriate so the level is between the minimum and maximum. Make sure you do this when the engines coolant is cold as the system is highly pressurised (1.2 bar and hot) so it can hurt you if you try removing the cap when it’s hot. Also fluid level changed when it’s hot.
Front and rear windscreen wiper check. Condition etc.
Tyres check for uneven wear and pressures (spare should be also check).
Check front and rear shock absorbers are correctly fixed no leaks etc.
Check bulbs work (brakes/indicators etc)
Check battery charge state.
Check all windows/mirrors for cracks etc.
Computer check of any errors logged in the ECU etc.
Some dealers will check other things i.e. tyre wear depth and top up washer fluid these should be a normal check anyway though as an owner.
Expect to pay between £120 and £150 depends where you are in the country. Shouldn’t take more than half a day but dealers ask for it all day so they can have work all day for the mechanics.
The auxiliary belt (known as the AUX belt) being changed this is about £100 extra on top of the normal A service.
