I take you mean adjust sensitivity of the alarm?? I took my Mk2 172 back because it was way to sensitive. The dealer removed my head unit to gain access to the alarm unit and swapped two wires over. Apparently this is the only adjustment you can do to the standard alarm. And its worked fine since.Quote: Originally posted by andy.m on 26 November 2003
you can not turn the sonics up or down its a compact alarm not a premier the siren does all the work
the alarm unit is not behind the radio its under the wiper motor you take the wipers off then the weather strip scuttle panel the wiper motor out and the alarm siren is bolted to the heater unit and the sonic wires are under the cup holders and ash tray with the led plugQuote: Originally posted by norfolkminis on 27 November 2003
