What.Yes get them!!! Had them on my golf gti, and for the money, they are quite possibly the best tyre pound for pound out there. Only downside, being fairly soft and grippy they will only last about 12months on the front (give or take depending on driving). Dry grip is always plentiful, but where i was overly impressed with them was the handling in the wet... they give you so much confidence round corners of all speeds, and when you do push to the limit in the wet and the grip starts to go, the tyres are incredibly pridictable in their behaviour, and control is easilly gained!
QUALITY TYRE!!
Sounds a good price, mine were about £30 fitted on 7J x 15 rims
T1r,s are much better. better edge to them and better in wet.
QUALITY TYRE!!
The.
f**k.
Were you driving on the same tyres as I was?? :S
T1-S are HORRIBLE.
Their wet grip is shocking - you have to tickle it round a corner as it'll grip a bit then just snap away, leaving you heading towards a solid object with no indication that you're going to regain grip in time.
Not only that but they have no 'bite' on turn in - they just roll over onto the sidewalls, leaving you with smooth shoulders and the rest of the tyre with loads of tread left. Not exactly much use as you then have to throw them away or risk 3 points / £60 fine...
If I had a choice of Goodyear Eagle F1 GSD3 on 195/50 or the T1-S in the same size, I would go for the F1s 101 times out of 100. No joke.
Get the F1s and I challenge you to find a better wet tyre.
[/rant] lol![]()
they won't get used in the wet... does this make a difference? They're going to be a sort of a road legal track car.
sounds crazy but I rate avon zv3's they are an almost unheard off british made tyre designed in this country on british roads. had falkens and various yokos, proxies and trust no european designed tyres will match avons for handling and grip on our s*&t roads wet or dry...
Went out for a play tonight, once you get used to it and drive smooth its not at all bad. Not great with standing water, and easy to get the car to understeer/ lose the rear should you choose to though.
All round far better tyre than the toyos were, sooo controllable. And in the dry once warm, by far the grippiest tyre ive used.
Scrap that idea mate.
Yokohama paradas are going for £40 delivered on ebay, 195/50/15s.
Ive just swapped a set of toyos for these, worlds apart in dry grip. Worlds apart.
What.
The.
f**k.
T1-S are HORRIBLE.
[/rant] lol![]()
Gotta agree with that, ive seen various threads about these tyres and i will say the same, they are crap, im seriously dissapointed with them, unfortunately i never read reviews here, just on other places which said they were good:nono:
Never again will i buy a toyo tyre, im trying to drive as hard as possible to get them worn down and replaced but that is a bit tricky as even with sensible/moderately hard driving you do not feel safe, in the dry they are acceptable but after any kind of precipatition has hit the ground cornering is non existent.
Avoid like the plague
Buy at you're peril.
