shortening shocks
_WILL_
  172 Cup
I'm with Phil. I know you can adjust how they react but to design them to purposely be used is f**king stupid, the damper/spring would be clearly designed wrong if it was the case.
Im not disagreeing but it happens. And they are tuneable. It's not that stupid tho as you can vary the rate of them in the same way you tune a car by varying the rate of the spring you vary the rate or hardness of the bump stop.
