Clio 172 cup
Hi Guys,
First, I'm new here so want to say hi
I have a sick 172 PH2 that I'm having trouble getting well. The problem I'm having is a really bad missfire and very jerky/shaking rough idle. The car also likes to kangaroo when in any gear - for example 4th gear at 30mph where you would expect to just drive normally it will jump all over the place.
I borrowed a fiends clip for a day but unfortunately there were no codes stored.
Replaced so far:
Coil pack
HT Leads (Euro car parts)
Spark plugs - NGK
Map sensor
TDC Sensor
Throttle Body
Pre cat Lambda
Cylinder 3 Injector
The only time i did get anything code wise was a cylinder 3 misfire which prompted me to replace the coil, leads, sparks which didn't make a difference then eventually the injector... but again no real difference in how the car runs
but the code has never been back since.
I still need to do a compression test but I'm scared to do so in case this means big bills
I'll try it this weekend hopefully
I have noticed something strange between 1000 and 2000 rpm which just happens to be when the car is at its worst - which I've uploaded to YouTube https://www.youtube.com/watch?v=FYCVDKvAGak&feature=youtu.be The pedal is still at this point - the needle is jumping around by itself. This is also the point in the rev range where the kangaroo thing i mentioned is at its worst no matter what gear you're in.
Also, here is a video of the idle https://www.youtube.com/watch?v=Z6KrguRtDns&feature=youtu.be
And, here is a video of the engine shaking around https://www.youtube.com/watch?v=-_GuXcWr6LA&feature=youtu.be
I've had the car lose all power when the rev range is in-between 1000 & 2000 rpm where the accelerator pedal does nothing.. this last for a few seconds and then car splutters back to life. The car is pretty smooth above 3000rpm
I'm not getting any noticeable loss of power nor is the car smoking from the exhaust.
I'm looking around Edinburgh to see if there are any decent specialists that can help me out so any recommendations are welcome. I'm hoping I've missed something obvious and you guys can point me in the right direction before i do though
Any help would be greatly appreciated!
Dave
Replaced so far:
Coil pack
Spark plugs - NGK
Map sensor
TDC Sensor
Throttle Body
Pre cat Lambda
Cylinder 3 Injector
Dave
