are they any good? I know you need to take care when using them but gonna buy a scrap bonnet and have a practice want some opinions and want something good but cheaper than a da
Going to striaght to a rotary is not stupid, but how do I put this politely, you have to have a bit of common sense to use one straight away. I used my DA twice and then sold it, hated it and then bought a rotary but im a fairly sensible-ish person.
On the threads you start todd (and I mean no offence here ) i wouldn't recommend you getting a rotary, and certainly not the silverline. Sure its cheap but its heavy and I could see you posting a thread along the lines of "Just used my Rotary for the first time and sanded my wing off"
Get a DA first as your less likely to do damage, get used to the techniques used then if you feel comfortable aget a rotary, a rotary only gives you better results if you use it correctly. They have a lot more bite and kick hen a DA.
In my case I seem to get on better with a rotary, I only bought the silverline as it was cheap, it will do want I want it to do (the odd correction on my car, missus and families cars). If I were to buy anothe I'd be going for a makita or something that doesn't weigh half a ton!
A DA has less chance of doing damage, I'd almost say anyone could "in theory" buy one and crack straight onto a car without fear of damage. Alas that isn't always the case although you are less likely to do damage with a DA. I'm used to my rotary but it still bites unexpectedly sometimes and it can be a bit hairy if you haven't got your wits about you.
Much like having a piss in the blokes urinals with your trousers round your ankles. Be aware.
Yes it might be a "bonus" but a DA is a hell of a lot better overall, for doing/covering most types of paint. In fact on certain soft paint types a DA is what you should use. I shouldn't in theory use my rotary on the EVO paintwork as its soft as you run the risk of burn through.
