Can these silvertec bulbs for mk2 ph2 headlights be bought from halfords? If so, which are the right ones? there are 3 at the bottom with different codes... http://www.halfords.com/webapp/wcs/stores/servlet/SearchCmd
...ok mate, The codes are BU501S, BU581S, BU343S, so i take it they are for all different cars. This is taken from the website just under the BULBS section, so i take it one of these 3 codes will fit the clio?
cool mate and i presume they were a straight foward swap?you need the BU581S thats what i got for mine
Is this for definate? dont want to buy the wrong ones again...you need the BU581S thats what i got for mine
ok cool, going to try another halfords branch tomorrow as im over that way. Are the rear lights also offset bulbs?I have the box in front of me, they're BU581S.
yes i think they are the same as the front ones but the best way is just get to halfords, pull one front indicator bulb out and one rear one then you can go in and find the correct ones!ok cool, going to try another halfords branch tomorrow as im over that way. Are the rear lights also offset bulbs?
ok cool mate, i take it the rear light is a straight foward job as well...Rear indicators are exactly the same bulbs.
You need two packs of BU581S.
that links guff mate.
what you want is the offset pin style
in the section by the bulbs for halfords there should be flip style cataloughe mounted on the shelf and you can find a clio and it will give you the codes for all of the bulbs the clio takes. then just find the code on the shelf and that will be the ones!![]()
Sod halfords. Buy them from here. I have and they're exactly what you need for much cheaper![]()
http://cgi.ebay.co.uk/Car-Indicator-bulbs-silvatec-offset-pin-bulbs_W0QQitemZ290267159951QQcmdZViewItem?hash=item290267159951&_trkparms=72%3A1301%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14http://cgi.ebay.co.uk/Car-Indicator...39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14http://cgi.ebay.co.uk/Car-Indicator...39:1|66:2|65:12|240:1318&_trksid=p3286.c0.m14
ive read your post thanks mate, ill get them from ebay if i cant get them at halfords laterBANGS HEAD AGAINST TABLE!![]()
