Simple network
J273
  RB 182
Just got hold of a lappy with wifi.....How do i go about creating a simple network between my main pc and lappy
Got
Pc connected to wifi router via ethernet cable and me lappy connected via wifi.....id like also to be able to print from the laptop through the main pc
Any simple guides out there guys?
  Fiesta ST
You can use simple file sharing if you like but your best off using proper NTFS permissions (gets a little more complicated though).
simple file sharing:
Right click a folder you would like to share and click - sharing and secuirty. Then click share this folder.
Permissions:
Everyone will beable to read from this folder on the network now. Make sure you allow file sharing on your firewall.
Printer:
Right-click your printer and click share - then on your laptop - add printer and choose network printer and then look for the printer.
Go one step further:
create a local account on your desktop PC (say laptop with a password). On your desktop logged in under admin account(main account) instead of sharing your folder for everyone under share permissions untick it and just add the user laptop. Now you can give this user more permission like full control.
So when you connect to the desktop pc with your lappy you log in with the laptop account with password.
J273
  RB 182
Permissions:
Printer:
Awesome.....Thanks Longy
Ill have a go in a min
dk
  911 GTS Cab
surely you will have to add them to a workgroup first though so they can see each other?
  172 cup'd extreme
rename both computers and ensure they have the same "workgroup name"
do this by right click my computer properties "computer name" tab
at the bottom it says "to rename this computer or join a domain click change" - click change ensure workgroup is selected and both computers have the same name.
restart both when prompted to
then right click on the items you want to share ie c drive and printer and choose "sharing and security" click share this folder allow users to change my files.
once you have done that go in my computer , along the top click "tools" and "map network drive" choose a drive letter and explore to your other computers shared drive or folder
also share printers in the same way by adding printer > add network printer etc
J273
  RB 182
Top man....works a treat.....Only problem ive got now is everytime i need to connect to the other machine i need to wurn the firewall off.
Im using sygate....does anyone have any ideas as to what port i need to enable for them to see each other?
woops sorted it now......was an option within sygate i forgot to enable
J273
  RB 182
Got it working fine using the above setup
The only problem ive got though is that i cant see the shared files that im sharing on the pc from the laptop
when i go to "tools" and "map network drive" choose a drive letter and explore to your other computers shared drive or folder on the Main pc i can view the folders im sharing over on the lappy
But when i do the same on the laptop...Tools -> map network drive and browse for folder
Under Microsoft windows network - > Workgroup the laptop and main pc are shown but when i click the + sign next to the main computer theres no folders shown
Dunno if you guys understand that :S
Just strange i can view the folders im sharing on the laptop but cant view them on the pc from the laptop
Any ideas guys?
J273
  RB 182
Finally got it workin....dont ask me how i aint got a clue lol
But it works...i now can view my docs folder on my main pc from my lappy
Just a thought though.....say if someone hacked my routers WEP key could they view my documents folder?
