Simple Question for simple person....
Car  ClioSport 172
Can someone please tell me how to change the drivers side - side light?
My hands are way to small to fit in there.
Also....what is the fuel rail guard? I'm not entirely sure.
I'm must sound like a right dumbass! :P
Cheers guys
Wait until a local school ends for the day and take a child, explain what they need to do, and let them get to work.
Never had to do one but small screwdriver at the base and lever it out (according to the owners manual). Fuel rail guard protects, well the fuel rail - it's in front of the injectors on the inlet manifold and is held on by two 10mm nuts (or one 10mm and one 13mm on some). Removing it requires a long socket to go in the holes.
Cheers for that guys.
I also have to replace the no. plate light.
Which seems easy enough....got it out and everything.
Bulb seems to be stuck though and don't want o force it incase i break it.
Is there a clip or that i need to use to get it out?
Failed it's MOT on four things.....2 of them being bulbs (sidelights and no.plate light)
The other 2....
Emissions - I suspect a injector as it's been missing for a while now.
Rear Drivers Side Brake - It's sticking on slightly....would this mean a new caliper?
Thoughts/Views appriciated.
A garage will chqnge these bulbs for pennies if not free. taking the bulb out should be a simple job push down and twist, if it breaks then use a grips to push and twist
Cheers....thanks for that.
Think i'll just take it to my local Halfords....my hands are waaaay too big! hehe
fuuuuuuuuuuuuuuuuuuuuuuuu!
i gave up changing my fog light bulbs because i couldnt get the b******s out... i didnt push down though :(
