Sky Signal
Car  182
hey people had sky installed the other week and the picture is crap and has lines running thu it
have a samsung le40rx lcd and matching home cimema kit
anyone no how i can fix the signal etc its from a comunial dish but the free view digital signal to the telly is a excellent picture
Bad weather causes a bad signal too. You sure its not just the weather?
I would try resetting the box though anyways like the person above suggested. Failing that, wait for some better weather :)
go into the services menu, under system setup, there should be a picture settings menu, go in there and change the signal from PAL to RGB, and make sure its connected up properly at the back.
Should look a hell of alot clearer once its been changed. Alot of engineers are too lazy to change that setting
Also have a look to see how its connected up, if the tv is connected via scart, make sure its plugged in the "TV Scart" socket, and not the VCR scart.
Also a better scart lead will help if your using the crap one sky provide :) if you have sky plus and are using optical out for sound look for an rgb only scart.
