Sky Wireless Broadband
  CS Dungeon
Is anyone else having issues with Sky BB?
My connection works fine for 30mins or so and then drops out and I have to reset my BB router.
It then works fine again for 15 mins and I have to reset the BB router once again.
This continues all f**king day and I am sick to the back teeth of talking to Sky call centres.
My phone bill this month alone to Sky customer services is £62 for 46 calls:eek:
Apparently I need to use a ethernet cable as Sky cannot fix the problem and refuse to send me another BB router. If I want an engineer to visit it is going to cost me £55:mad:
Does anyone work for Sky or have a number to guaruntee someone who remotely speaks the queens English?
Clart
lol i had that. You need to escalate to 3rd level support where they will log into the local exchange and cap the line at a lower bandwidth.
Chances are that you're getting errors on the line which are gradually clogging it up to the point where it just doesn't send /receive any data.
I had the same thing, ended up ringing them about 20 times with no success. When i got code from threatening to leave, the problems completely vanished!
I would consider buying an ethernet cable and testing via a wired solution.
I feel your pain brother...
Tom
  EV (s)
You attempted to go through the channels?
802.11g has a very short range with those netgear routers. So avoid using G only, set it to Auto.
Try using 802.11b on your pc's network card. and cycling the channels.
  CS Dungeon
Cheers mate, its just as you explained.
I am using Vista Ultimate and in the network centre it is still showing that I have a connection to the Sky router and the internet yet pages are not displayed and all I get is 'page cannot be displayed'
Wired works fine, but the router is downstairs and I dont want to pull up the flooring to hardwire a cable into a wiresless router lol
Sky's CS told me to move my PC down stairs nearer the Router...............I dont want my PC downstairs FFS ARGHHHHHHHHHHHHHHHHHHHHHHHH
I wouldnt mind so much if the customer service mugs new what they was doing.
I was on the phone for 35 mins last night to a philipeano (bearing in mind I am having the problems on my desktop pc) when the bint asked me if it was a laptop I using..............she had already asked me this 3 times
After 55mins I got told that its my wireless network card and that they do not support Belkin cards so she hung up, .......................I was fuming at this point
  182
If you think its a problem with the router, just unplug it from the power, phone sky and tell them its busted (not powering on). They will send you a new one
  CS Dungeon
I'm not 100% sure it is the router, have read on other forums about security issues............something to do with Sky BB router using WPA-PSK
  182
I never had any problems with mine. You can change the encryption type or turn it off all together as a test.
