Slight miss and intial hesertation
Car  Clio 172 Ph2
Hey all the Ebay scrapper is in work for its mot on Monday but in the mean time after a full service, inc plugs and a new coil pack there is still a miss fire and lag when initially opening the throttle.
i've cleaned the throttle body and the inlet manifold but its still there....no faults on CLIP and no missfire recorded but its definitely there. Leads will be swapped tomorrow when then come but if all else fails throttle body on its way out?
Sven
I have this problem as well, changed the throttle body, injectors, cleaned the Tdc sensor also changed lambda
Nothing seem to cure it, next on my list was coil pack, ht leads and spark plugs see If that helps. If you find out what it is let me know
