Smell of burning rubber at idle
  Clio 182 turbo
Hello
I have a ph2 172. I started it up this morning and left it running for a several minutes and I could smell a faint smell of burning rubber which I think is coming from the belt area?
Any help please
also best place/price for a cambelt change near ba3 postal code
​josh
  Clio 182 turbo
I tried to have a look couldn't really see anywhere that was rubbing I will need to have a closer look thanks tho
  Clio 182 turbo
Yes it still runs. Idle is smoothish slightly lumpy and when it is cold has a small ticking if that makes sense. I have renewed the insurance on it. So hasn't been on a road for a month. The only thing I have done recently is replaced all the engine mounts as the old ones were worn
  Clio 182 turbo
Thanks for the advice mate I be sure to get it checked out. That will be something else added to the list :)
  Clio 182 turbo
Will keep you in mind mate :) good to know some one is near by. I don't really want to go to renault themselves
  Clio 172 phase 1
I've used dan &sjm josh and he's sound really knows his stuff I had a belt done on mine where the timing was slightly out took it to him to have it all inspected and all that much better now his works good plus bath - glastonburys deffo worth it spesh to know its all done properly :)
