Smelling rubber!
Da
Trader Rating - 100%
48   0   0
  Less
1. Use your judgment to post in the correct forum section. Any post not in the correct section may be moved without prior notice to the correct forum. A redirect link will be visible for 1 hour. If you have posted a thread and you find it is no longer there, please use the search function first as it may have been moved, if that doesn't work then please pm a moderator online. If you cannot post in the correct section, possibly because you're not a Club Member, do not post elsewhere in the hope a moderator will move the thread for you. If you want full access to the forum please join the Club. Persistently breaking this rule will result in a minor infraction (1 point).
