As per title. Just about to install Windows on the Mac. Anyone had any issues does it run ok? Will not be used a huge amount but I need the the option to boot to a Windows Environment. Don't want to use Parallels or anything like that.
The only issues you might have will be driver related. Any driver that works in Vista & 7, should be fine, as you'll just be using the Apple bootcamp Vista drivers?
In my experience you'll have to use the bootcamp drivers from your OSX DVD once in Windows. I tried an XP installation some time ago, and found that the standalone drivers wouldn't install. According to Google it's quite common.
Thanks lovelys. Just about to try now. I have run XP on there before it seemed to like the drivers with Bootcamp. But no doubt this will c**k up. Snow Leopard disc is at work as well
Windows 7 runs fine on my macbook, the only issue I have is my backlit keyboard will not switch off, keys are always illuminated.
It's only a slight issue but hey, it still works.
Just make sure you update the graphics drivers and all the aero effects should work perfectly
