Some amp Questions
Car  Clio 1.2 16V Dynamique
Just wondering, if only the power light comes on an amp does this mean it is connected up correctly?
Also is 10G wiring suitable for a 500W amp with a 500W (RMS) sub?
Yeah, well depends how many lights are on it i guess. But to have it connected properly you should have the live from battery to amp, remote wire from the back of the head unit to the amp and also a ground point going to the amp and the RCA cable going to the head unit.
not quite sure on the wire
does ure amp give out 500w RMS in 2ohms then?
Its 500W max and its 4ohms when in bridged mode. At the moment I am only holding the battery cable in place and and I'm getting a bit of bass from the sub but its quite quiet, do you think it should be fine if I screw the cable down?
