Powering 6x9s from the head unit will do you no favours...
But just extend the rear speaker wires... easy 10 mins job.
thanks, that sounds like the way forward, are the sides gummed together like the front doors are? (simply, for someone who has no ability in this kind of thing, how much swearing is involved?)
Terrible Terrible plan..... I cannot stress enough how crap HU powered 6x9's will sound. Uprated speakers are often worse than OEM speakers without an amp.
DO NOT DO THIS.
Either, buy a cheap amp (if budget is an issue) JBL amps can be had on ebay for less than £30, they're the best budget car audio manufacturer IMO. OR, buy a pair of component speakers.
Like this for example.... It's tatty, but it's cheeeeaaaaapppppp. A bit more wiring to be done but there we go.
http://cgi.ebay.co.uk/jbl-gto-75-2-...ent_GPS_Car_Amplifiers_PP&hash=item41540564e2
Trust me, if you put them through head unit power, they'll sound crap and you'll end up buying an amp anyway.
I honestly can't say I agree, I've heard many HU powered speaker set up's sound fine to the "general ear".
If you want to just go for the powered off the HU option mate, I'd be willing to lend you a hand, wouldn't take long at all.
Cheers Jack, I'll bear it in mind.
only problem with an amp is that I've nowhere I can put it now. You cant undersling it to the shelf and I've already got enough boot space filled by sub.
I'm only interested since there's a lad on here offloading a shelf with Vibes already fitted, so I thought "why not?"
Back of the seats was an idea I had, would go well on the 1/3 section, but there doesn't seem to be anything solid there?
I just need a dry weekend and some tools to see how this damn car comes apart, hell, it cant be that bad if a series of bumps can reduce most renaults to their individual parts
I can see this being ok if you have a great HU. If it's something average, they'll sound awful. But by all means, except a bit of time wiring, you don't have a whole lot to lose.
Most 6x9's will require about 100 - 125W RMS, most Headunits will output about 40 - 50W RMS (which I've always found to be a bit optimistic) per channel, clearly a huge difference.
You'll get hideous amounts of clipping at higher volumes, particularly with lower frequencies.
Most put out around 20w rms youll find, 45w max
just upgrade the rear door/panel speakers instead.much better
They all state max not rms values
