Sound Deadening Question.
Car  Twingo Dynamique
Hey hey :)
Just about to fit some silent coat - in the boot lid, do i stick it, across the outer hole, to block off the hollow space inside, or just stick it on the inside of that hollow space...?? i can get pics if needed. cheers :)
I assume it's the same for doing the rear quarters and front doors? Also anywhere else you recommend to put some deadening if i have enough left over?
you can do both skins if you wish and you can put it pretty much any were mate that has a problem but dont expect it to stop every noise
Gaah, put the door cards back on now.... But I'll put some on when I get the sport ones. Which bit do i do.... The back of it which faces the door yeah?
What I've done today - both doors, two sheets of silent coat.
