Spacers due to rubbing tyres
  Clio 200 LY/SV650S
After buying some spacers for my car 1.2 Campus.
The car is on 205/45/R16
Currently the back tyres are enjoying their time bonding with my suspension, that close I cant even get my fingers in the gap between them.
So after getting these spacers
http://www.lkperformancestyling.co.uk/product.php?ctn=deltamicswheelspacers&product=619
2 x 25mm at £38
Any issues with these? Or better prices else where? Seen few on ebay but after reading on here I understand that some materials are to put it simple crap, some also cause wheel wobble.
Basically I'm just looking for tried and tested spacers and advice.
Gally
It may be scraping on your outer edge after you put spacers on.
Then you will start shredding tyres!
  02 Clio Extreme
True.. unless you get stretched tyres.
I got spacers from a local shop in my area, they not the cheapy ones, but no brand name either.. they are brilliant, no wheel wobble.
Btw - if u buy 10mm spacers or above you will need the extra long bolts.
wheel wobble occurs if the spacers are not hubcentric.
hubcentric means the spacers have a lip, just like the hub, which the inside of the wheel sits on, thus protecting against movement.
205 are very wide for a 1.2, especially if it is lowered. i run fk suspension with 15mm spacers and my tyres will rub on the outside lip of the arch if i have loads of stuff in the back, i therefore remove them for trips like this.
jamie
  E92 M3
mine dont rub at all i hav 205s on and mine been lowerd 40mm and i can hav 5 people in. i have nothing on the back and 25mm on the front
yeah its the back lad, and if you are on coilies it will rub on the shocks if lowered loads, hence i had to get spacers fitted before my coilies.
jamie
why I'm looking at this thread I've got a question:
The hubcentric are obviously the best spacers but am I right in thinking that the 5mm spacers only come as non hubcentric?
i think the rule is up to 6/7mm you are ok, but 10mm and over has to be extended bolts, 20mm and over is bolted to the hub, then use original bolts to bolt the wheel to the spacer.
jamie
