Wheel/Tyre Suspension Clearance
JamesBryan
  Titanium 182
Just fitted my camber bolts and had them dialed in to -1.5 deg.
I'm now thinking the inside edge of the tyre might be too close to the suspension spring, especially on track under hard cornering.
I can just get my fingers in the gap between the two, so say roughly 10mm +/-. Is that enough?
Would it be worth getting some 5mm spacers for a bit of extra clearance just in case?
  Teg
What offset wheel you got pal? Just fitted camber bolts on mine and getting it aligned tomorrow for neg 2 degrees... I've got cup turinis so hoping I'll be ok now.
JamesBryan
  Titanium 182
Speedline 2118 which are ET43, so 5mm spacers would take it out to ET38 which is what Cup Turini's are.
You should be ok mate.
