Spacers - Help
  Fiesta ST-3
I need some spacers to sort out my stance. Now I think 20mm will be about right, which I presume means 10mm each side. What exactly do i need? Hubcentric or what not for the front and back? Help would be appreciated as I clearly don't have a clue about them.
Cheers, Chris
20mm, per side, front and back. (10mm per side won't look any different)
Ideally you want FK Hubcentrics.
Venom Motorsport sell them.
Increasing the track will put a lot more strain on your suspension/wheel bearings, especially the front.
Don't panic about the strain.
I ran 15mm front and 25mm rear fk hubcentric spacers for thousands of miles in my tt which was still fine.
I need some for mine, 10mm front and 15mm rear me thinks.
I would use spacers on the back axle but not on the front. I really think it's a bad idea on any car unless you are correcting an ET gap.
Thanks for the help! Appreciate it. Ill get 20mm just to be safe, i'd rather not wreck my new tyres! Cheers for the heads up on the wheel bearings etc too
