SPACERS? QUICK HELP
Car  BMW E92/Audi S3
FIRSTLY, PLEASE EXCUSE THE CAPS.. IM GOING TO RESTART THE PC IN A MINUTE..
BUT, MY NEIGHBOUR/FRIEND CAN MAKE ME 10MM SPACERS FOR MY CLIO. 2 QUESTIONS..
WHATS THE MEASUREMENTS OF THE MM'OD (OUTTER DIAMETER) AND THE MM'ID (INNER DIAMETER)?
AND, AM I GOING TO NEED BIGGER BOLTS? THANK YOU IN ADVANCE IF YOU IGNORE THE CAPS
There was something wrong with the keyboard..
But moving on.. Anyone know the MMod and ID?
I most likely will when i find out the I.D and O.D. I'd take off my wheel and look myself but my bolts are VERY tight because some so called 'mechanic' didnt use the correct torque settings..
Its for something u guys most likely wont like but i need them! haha..try extending your handle with a bar or something.
I shall PM you and let you know if i can get you 40mm spacers, all around? ALSO.. The bolts are NOT included
Ideally after spacers where i bolt the spacers onto the hub then bolt the alloy onto the spacer. if uno what i mean? yea will need a set of 4..
