Spark Plugs???
Car  RenaultSport Clio 172 Mk2
Hi everyone , I need to change my Spark Plugs on my car and I want to know which ones it the best to use if you looking perfomance wise?:S?
About 37000..I stay in South Africa so it's on 60000 km's now..i think it's the major service..And it's a Clio 172 Phase 2..
Shouldnt really need to change the plugs just yet, should last to about 70000miles, but if your having problems then just change them for NGK recommended plugs>
http://www.sparkplugs.co.uk/pages/pricing/applications/ngk_petrol_car_applications.asp
None will give you a performance gain, unless your engine is highly tuned, Plugs a plug Just make sure you get the right temperature and thats it.
The ones in now should be Platinum plugs, which are about £18 a plug, very good, wouldnt change them unless you know the problem is with the plugs..
[FONT=&quot][/FONT]
Standard NGK plugs (PFR6E-10) will do fine.
I've just fitted a set of Bosch plugs (Super Plus, Yttrium 8+), (due to cost), and they're fine too.
I'd get them changed if I were you - I'm a bit skeptical about the 72,000 service interval).
is it a problem that i have replaced one spark plug with my friend's opel astra 2002 1,6 ??
one of mine spark plugs was measuring 0,5 ohm
the 3 other were about 3700 ohms, this one from the astra was 4300 ohm
since the shape was the same is it ok ??
No it's not, get a matching set of spark plugs for the car brand new from the correct application
I ordered one set ngk from eurocarparts but i have to wait for the shipping
I will use old spark plugs just this time
Its Ok ?
