I have got a set of 6 inch kappas and a set 4inch kappas! what do you think are best of the clio? Only want to replace the fronts as there is a nice box going in the boot!
The 6" Kappas will sound much better than the 4" ones. MAke up a MDF Spacer and you should be able to fit them. Depending on the magnet size you may have to cut a little metal.
The only problem is the plastic cover behind the speaker and possibly the metal, but that depends on the basket size of the speaker, obviously bigger the magnet the more hassle
No problem MAC
