Speaker stops working intermittantly
  C4 Grand Picasso
The speaker in the right door (52 plate) has been cutting off every now and again - I found that a quick angry punch gets it working again. I took out the speaker thinking it was a loose wire but everything seemed solid enough, has anyone any ideas what it could be?
Cheers,
Mike.
  C4 Grand Picasso
Will have to check the connector again to make sure then, may just solder it on to make double-sure.
  C4 Grand Picasso
Yes, it is a standard speaker and today was the first time Id touched it - I have some old crappy speakers in the shed, I will temporarily hook one of them up to see if that solves the problem.
Cheers guys,
Mike.
My moneys on shorting. I had this with phono cables from an amp that were being cut by the rear seat fixings in my old AX.
Deeg
It might be earthing, I had / have this problem with a set of after market speakers, cos they were installed by a muppet.
Some part of the speaker touches the metal and cuts out (from what i was told). When you hit it, which I used to do to, but mine was passeneger side, so got some people very worried on the motorway, it knocks it back in place.
