My speakers are not working, but my subwoofer continues to play? What is this?
If it is all your speakers check the connections behind the headunit (and make sure you haven't turned them off in the settings), if its just one speaker check the connection behind the speaker. Both are easy to get to.My speakers are not working, but my subwoofer continues to play? What is this?
crack on then fella.
But yeah, uprated speakers....means it time to wire in an AMP! :smiley:
In fairness the stock speakers are generally good provided they dont get a hole in them. They certainly handle a 4x50w headunit without a problem, I found.
Use your high-pass filters though, regardless of speakers, cut off bass to the speakers as it's a waste of watts if you have a sub in place.
