Clio 172 2001 ph1
Hi Guys,
Just wondering if anyone has had the same/similar problems.
On the motorway (hasnt happened below 70) at some point in the journey the speedo drops to 0 for usually the whole journey until I come to a stop and pull away again, then it has been fine so far until I get up to 70 ish again where it is temperamental.
Also in higher gears at lower revs the car has a slight judder as if misfiring or skipping a beat. And before you say it, no I am not running the engine to basically a stall point. For example it happens in 4th at about 25-30mph when you put your foot down.
Plugged a diagnostic machine in and it says knock sensor issue. However every thread I have read on here points to it being the speedo sensor. Can anyone shed any light? Going to re-diagnose tonight as last time I deleted the code to see what happened and it still carried on.
(put this in here as well as in faults/problems as someone may know)
