Speedo Help
Hi can anyone help me I have a 52 plate 1.2 clio with ABS and the speedo does not work I have had it working in the past but its playing up again. All other gauges on the instrument panel work and all gauges sweep as they supposed to do in self test. I am trying to work out where the wire that drives the speedo comes from i've looked that it should be a violet wire from the ABS on the drawings i have it says pin 23 but when i remove the backshell of the connector the violet wire is pin 22 can anyone shed any light on this and also to what pin on the instrument panel this should go to.
Mike J
