Speedo - not working (only sometimes)
  RenaultSport clio 172 mk1
Anyone had this problem before. Speedo works and then all of a sudden no speed reading (rev counter etc all working still) then the needle kicks back in and is working again or for a while and then the same happens again.
Is it a fault in the ???? where to look??
Change the speed sensor. Easy job to change, it is locate near the manifold. Just remove the chrome protecter and pull it (require some force)
pic for your reference.
I have one for sale if you are interest. PM me.
  LY 182
not sure what the speedo drive is like in these not looked at one and not sure what part of the box its driven off- but on alot of cars you find the when the speedo is driven by the diff when the speedo stops working its generally because the box is knackered.. the diff develops end float and wears the teeth off the plastic worm gear.
