speedo reading 5mph out, according to satnav?
Car  172 cup
In my 01 1.2 16v dynamique, noticed the speedos out 5mph or so when im using the satnav. is this normal? as on my previous car it was the same except when i swapped the 13 inch wheels to 15 inch this sorted it.
any advice?
sat nav speed is based on straight line ,level and flat , your speedo measures over any terrain. think of a triangle over the top is a longer distance than across the bottom
speedo will only ever be accurate up to about thirty. I would say that having worked through four cars in 18 months, but with the same satnav, clio's are especially bad!! ;)
