Speedo Vid....Bored Last Night
  Looking for a ph-quick...
well theres about a second before i actually start and u can hear the music, so really its bout 8!!
i think it shud b alot quicker, its chipped, induction kit, and decated stainless exhaust exhaust
unless my driving is gash lol
Amir
Cheers Finch
Gonna try again later when its light. Should really stop spanking her. Gas flowed cylinder head is on the way! :D
Amir
def 9 secs, I hit the stop watch as soon as it moves and stop it at 63mph (true 60mph) checked it 3
times now, still 9 secs...
you should know that the 0-60 time given in books are used with timming gear to hit 60 spot on, but ALL speedo's over read, 63mph is closer to real 60mph.......
Simon
Get you!!! with alll your technical stuff!!1
lol cheers for the info anyway pal!!!
riiiiiiiiiiiiiite, wel either theres something seriosly wrong, or im just doing something wrong, changed to earlier, the chip in the ecu has lifted the limiter to just over 7000rpm.. i'll give it another blast when i finish work, might swap the ECU over aswel see if its any slower.
opninons??
Amir
Yeah that 3rd gear change is what is slowing your 0-60 time down, if you could only get there in 2nd you'd be laughing, try 0-100 (104-5mph on speedo) and see what you get :)
Simon
no mate they rev to 8000rpm, that whats on the clock anyway and mine reved to that b4 the chip was installed.
Amir
  Beetle
no thats not what i mean. the clocks go up to 8000rpm, but they hit the limiter at 7000rpm as standard.
  Golf MK7,GSX-R600 L4
if all cars over read on the speedo then its fine timing it to 60 or 100 on the speedo, otherwise the time will be out of sync with what everyone else times ...if that makes any sense lol
Yeah but if you compare them with "The BOOK" time then you think your car is faster when is not, so its misleading, yes?
If you run it to 3mph at 60 and 5mph at 100 you will be more accurate at least.... :)
On a speedo vid, like the way people on here do them, I could get my v6 to maybe under 5 seconds, which is NOT true, so I'm only KIDDING myself, yes? ;) :)
will try sometime soon and see..... ;) will be intresting to see if I'm correct or talking b****cks....lol ;) :)
Simon
Deffo get a Vee speedo vid up mate, will be good to see. I know where your coming from with the speed vid thingy, its the roughest of rough estimates, espec with a stopwatch. So your prob best to add on a second odd:rasp:
Damn i thought my cup hit 60 in under 6 seconds.....i thought they all did:eek:
  Saxo VTS
Tbh just time it to what it says on the speedo and stop being gay :D
Valvers limit at 7000Rpm from standard, Williams 6500Rpm.
bass_direct
  375bhp mk1 +Williams
opninons??
Amir
Yeah for some reason doesn't look as quick as it should! should be hitting 65ish on the speedo in second gear!
