splitter
Car  clio 182
does a splitter cum on all 182 cos my one does not have one it not where can i got one from
thanks
james
Look for screw holes on the underside lining of the bumper, easiest way to see if it's had one on?
If it doesn't have the cup rear spoiler than it's not meant to have had a splitter, as said check for screw holes to see if it ever had one on it.
Non cupped packs didn't come with them and those that did, it often came on the back seat and some dealers took to pinching them.
Hence the difference between a dealership and stealership that are out there these days :rolleyes:
I just got off the phone to BRUM before, ph2 megane splitter (thin one similiar to a cup)
£57.59
And that's only up to the 31st January, VAT increases 2.5% again then so will be more.
Pretty much any splitter will if you can bend/chop it to fit dude.
The big splitter on the 197 isn't one of those, as it's about 10 inches thick :)
the carbon ones from ktec are cheaper than reno iirc.
Other splitters that fit well are 307, megeane or languna that you should be able source from a scrapyard
Mine also didn't come with one and it had the Cup Packs as well. Just got a small 307 splitter which only cost 39.99 from Peugeot. Bargain IMO.
