Sportlines...
  RS6+ & 40d MSport X5
Will the above that are currently fitted to a 182 fit on a ph-quick?
Thanks Gaz
  e92 + E46 M3 + Cup
Yea should be fine, The standard 182 uses the same dampers as the 172 Ph1 & Ph2, belive even the 182 cup uses the same its just the hubs that are diffrent
James
koi
You got a 172 again??
You change cars more often than I change my boxers!!
Pauls by any chance????;)
